No Heat...can someone help? plz!
Old Mar 3, 2008 | 11:30 PM
revriff's Avatar
Default No Heat...can someone help? plz!
MY HEAT AND AIR CONTROLS DO NOT WORK I NEED HELP FINDING A SOLUTION I have a 2001 volvo S40 THAT HAS NO HEAT. I'VE CHECKED THE FUSES AND THEY ARE OK.......I NEED HELP OR ADVICE AS TO WHERE i NEED TO CHECK NEXT. MAYBE A RELAY?
Old Mar 4, 2008 | 12:20 PM
zerochills's Avatar
Default RE: No Heat...can someone help? plz!
is the blower operating normally? if so, and you are getting a/c then check the coolant level. if the coolant level is to lw then the heater core will not operate properly.
Old Mar 4, 2008 | 08:42 PM
revriff's Avatar
actually none of the controls are working...be it, air, heat etc. I'm hoping there is a relay or something that has gone bad......any more thoughts on my problem?
Old Mar 7, 2008 | 09:26 AM
Hudini's Avatar
Did you check both fuse boxes? One under the dash, one in the engine compartment?
Has your car had the recall done for the blower motor?
Old Mar 10, 2008 | 07:35 PM
tr_car_nut's Avatar
This sounds like the fan resistor has gone bad. If you are not getting any fan power no matter where you set the fan speed then it probably is the resistor (it's in the fan housing).
[IMG]local://upfiles/14357/8CE46163EE3A43B18A598B75A19F792B.jpg[/IMG]
Hima_nassef
Apr 5, 2012 05:52 AM
yungprofit703
Mar 23, 2011 08:52 PM
koster
Oct 11, 2009 08:19 AM
bunky3301
Mar 25, 2008 06:38 PM
OverTheTop
Sep 29, 2005 01:04 AM
