Not shifting, stuck in high RPM's
Old Apr 23, 2013 | 12:10 PM
Chuckie007's Avatar
Default Not shifting, stuck in high RPM's
I have a 2000 S40 Turbo and have recently been having issues with it shifting out of first. The rpm's just keep climbing and there's no rhyme or reason as to when it decides to jump into gear. Sometimes taking your foot off of the gas, letting them drop and then start accelerating again will work, shifting to a lower gear will sometimes work and sometimes it'll just do it on its own.
Thanks in advance for any help,
Chuck
Old Apr 24, 2013 | 06:53 PM
Hudini's Avatar
Can you manually shift from 1 to 2 to 3 using the shifter? (i.e. not just put it in D)
Old Apr 25, 2013 | 07:04 AM
Chuckie007's Avatar
Yes. That was actually how I got it to drop into gear last time. I put it in 3 and it seemed to do the job.
Old Apr 25, 2013 | 10:26 PM
Hudini's Avatar
Is the weather button pushed in or the "up arrow" on solid? (hopefully not flashing) The car will normally illuminate the check engine light and set a code with a trans problem.
Have you checked the fluid level? Color? Smell? Low level, brown color, or burnt smell = bad.
stefan1988
Mar 25, 2013 10:37 AM
janeofdrama
May 24, 2010 08:02 PM
oldskoolsteve
Aug 21, 2008 11:01 PM
daver80
Dec 11, 2006 09:15 PM
