Oh my god… Code P0740, and P0733.
Old May 13, 2014 | 03:58 PM
bryants40's Avatar
Default Oh my god… Code P0740, and P0733.
To add to my countless problems with this 2001 S40, my transmission just went into "limp" mode I'm assuming…
I was on the freeway when my engine about redlines, but has no power. I let of the throttle and pulled over.
On my adventure home I was only about to go about 20-30 miles an hr…
I can only use reverse, and sometimes the 3rd gear. (While shifting through)
Last summer I have the fluid serviced.
The car has a flashing arrow, and an engine light for p0740, and p0733...
Old May 13, 2014 | 09:30 PM
difflock54's Avatar
PO740 is a TCC circuit malfunction. (Torque convertor)
PO733 Gear Ratio Incorrect.
the torque convertor problem will be causing the 2nd fault.
An electrical failure, probably resulting from a solenoid problem.
see links below: useful information.
P0740 Torque Converter Clutch Circuit Malfunction DTC
P0743 Torque Converter Clutch (TCC) Solenoid Circuit Electrical
Old May 15, 2014 | 04:10 PM
bryants40's Avatar
Now my car will fall out of gear with no notice other than the lack of power, and the rpm raise… I drove it to a shop they could not tell me anything…
Wiring all looks good and I put electric grease to insure all the plugs were in there good. No change.
Old May 15, 2014 | 07:49 PM
difflock54's Avatar
Is the ATFstill a cleanish red color or well overdue for a drain and fill?
Was the correct ATF used when you had it replaced last summer.
The 5 speed transmission must have JWS3309 spec'd fluid or problems occur.
joshula8
Feb 11, 2013 05:07 PM
spankey
Apr 9, 2011 03:58 PM
dphilips75
Oct 21, 2009 12:32 PM
rob960
Jan 20, 2008 01:47 PM
TheSteelKnight
Aug 22, 2007 12:18 AM
