Oil Cooler line tee
Changing exhaust gasket caused oil leak? (Solved)
Hello, (2008 s40 t5) I just replaced the exhaust manifold gasket on my Volvo, after letting it sit after taking a little spin I noticed a lot of oil under the car. I think I know the source but I dont know if this valve is supposed to be plugged or if its a check valve. Any help would be great Thank you
I have oil coming from up above the cooler itself from this fitting, I just need to know why that fitting would be leaking so much
So after looking closer I feel the leak is from the turbos oil return line. But its not leaking at the turbo, but from where it goes into the block. My only reason for thinking this is i left that line connected when i moved the turbo and exhaust back to replace the exhaust manifold gasket. So im thinking it messed up the seal at the block, is that a simple fix?
31251456 GASKET $2.96
31251439 SEALING R $1.73
Tim
800.234.5394
gilber33
06-23-2011 06:23 PM
