Please help!! Cam locking tool broke inside camshaft!!
Old Jul 21, 2021 | 01:36 PM
NathanDoty's Avatar
Default Please help!! Cam locking tool broke inside camshaft!!
Hello im new to working on volvo's. My daughter has had a 2005 volvo s40 with the 2.4i B5254 S4 for a while now ran into some issues with a leaking head gasket. I did the research, watched a million videos, ordered all the parts and tools and thought I understood everything. Last night when trying to put the rear cam locking tool on one of the bolts broke off inside the camshaft before it even tightened up. I am not sure what to do next. Do I try and remove the bolt or does the whole camshaft have to be replaced? How do i get the timing right if I do have to replace it or if it does move? Any help would be much appreciated as I am needing to get her car back on the road as soon as possible.
Thanks
Old Jul 21, 2021 | 02:09 PM
firebirdparts's Avatar
If it threaded in easily to that point, then it may come out pretty easily. It's different when you're trying to remove a bolt that has been rusted in place for 40 years. This is new, and it's located where it couldn't rust.
So a basic response would be to get a left handed drill bit and start drilling the center of the bolt with your drill in reverse. Likely it'll back right out. If not, and you get a hole instead, you could use an "easy out" in that hole.
Old Jul 23, 2021 | 05:02 PM
NathanDoty's Avatar
So I have tried left handed bits and screw extractors and I cant get the stubborn bolt out at all. Any additional ideas would be fantastic. I can get the timing done with out the locking tool. Will that bolt cause issues if I leave it in there or will I have to replace the camshaft.
psrock
Jun 6, 2018 07:01 PM
jaquelperdue
Feb 25, 2011 11:57 AM
TomT
Jul 29, 2010 08:43 PM
ducksauce
Oct 15, 2009 08:07 PM
silkhope
Jul 4, 2009 12:32 AM
