possible fuel pump issue?
Old Feb 23, 2010 | 06:11 PM
240_canada's Avatar
Default possible fuel pump issue?
Hi all,
I have 1992 240. 246,000 kms. Low, I know.
Recently its engine has been cutting out at idle a bit. Then the other day, I was driving and it started sputtering. I called BCAA, and the guy changed a fuse. It ran great. Turned out, it was the fuse to the main fuel pump. The check engine light went off and it ran better than it has in a while. Later that evening, the check engine came back on and it started sputtering (losing power) again. I checked the fuses and they were ok. My gas was just below quarter, so I went and filled up. It ran mostly fine, still with the check engine light on. It occasionally does the sputter thing, but runs well as long as I keep more gas in it.
What do you think of this problem? What could it be?
Thanks in advance.
spidersilva
Aug 17, 2011 07:23 PM
orcutd
Sep 27, 2008 08:13 PM
montysano
Sep 9, 2008 11:52 AM
lemans24
Nov 23, 2007 11:44 PM
