Power Steering and Fuel system cleaner
Old Sep 8, 2007 | 06:19 PM
nordx's Avatar
Default Power Steering and Fuel system cleaner
This is a two parter:
Should power steering fluid be replaced every now and then? If so when?
Does Fuel System Cleaner, the stuff you pour into your tank actually work, or is it just a con? If it does work which is the better manufacturer?
Thanks
Old Sep 9, 2007 | 08:43 AM
Default RE: Power Steering and Fuel system cleaner
You can flush it if you want to. I would say like every 60k or 90k would be fine.
The fuel system cleaners work pretty good.
I swear by techron. It is a little expensive but works good.
Old Sep 9, 2007 | 10:44 PM
JPN's Avatar
JPN
Techron has good reputation among professional technicians.
As for the steering fluid, be sure to use the specified fluid, DO NOT use generic power steering fluid. Check with your owner's manual for specified fluid.
JPN
RKnoxAZ
Jun 8, 2013 07:10 AM
dcjcdc
Apr 23, 2012 04:47 PM
a4ty4d
Sep 29, 2010 01:54 PM
chodorowski
Jun 17, 2009 03:12 PM
Capo Cam
Feb 20, 2008 11:00 PM
