Problem resetting radio code
OK, so I read instructions for resetting the radio to accept activation code after inputting incorrect codes and the instructions called for leaving the radio on for from 15 minutes to up to four hours. After doing so I had a dead battery which I've recharged and now the radio screen reads "OFF" and doesn't accept input (or at least I've not figured out how to get to the screen which will allow input of the activation code.) What am I doing wrong?
Thanks
Thanks
I had the same problem. I would just go check on it every now and then. But I did have to go the 4 hours. If you continue to have code problems, call Volvo customer service. You can get the number off their website. Tell them your problem and they will ask you for your vin and give you your code.
rspi
04-12-2013 04:21 PM
