Ref: Cat con removing, inspection, refit!!
Hi all,
Was just wondering if i can safely remove my cat convertor without any major hassles, what do i have to do, is it safe to remove it, can i do a physical inspection on it if removed.
Thnx
BraderzMMX
Thnx
BraderzMMX
All that said, I have heard of other folks removing one or both of the converters. You may have issues with the back O2 sensor as it expects the converter to be there.
Ok, I'll bite. If your car has to go through emission inspection you will very likely be hassled by the inspector. If you don't have a good way to lift the car off the ground it will be a major hassle to remove the converter. If you remove it, it should be very easy to inspect. In fact, it will be much easier to perform a complete physical inspection of the converter when it is off the car.
