Turbo replacement
your car has a Mitsubishi TD04L 12T. The TD04 refers to the turbo housing design and the 12T is the pumping capacity. The T4 version (ie the high pressure S40) uses a TD04L 14T which can be found on some S60 models - but you may have to rotate the housing slightly to get it to fit - search for some posts/vids on the subject but that'd be the most cost effective way to go.
HummerGuy
02-14-2009 09:23 PM
