Turbo replacement
Old Sep 28, 2005 | 07:05 PM
katrina's Avatar
Default Turbo replacement
Hi I am shoping for a new turbo for my 94 850 and I am wondering if i can use a later year turbo like 95 or 96.
Witch other model cars have the same or better without diferent mounting holes?
Thanks
Old Sep 28, 2005 | 09:22 PM
Default RE: Turbo replacement
Which turbo do you have?
Old Sep 28, 2005 | 09:35 PM
katrina's Avatar
94 850 turbo
Old Sep 28, 2005 | 10:22 PM
Yes but I beleive they had 2 different turbo's on the cars.
Old Sep 28, 2005 | 10:28 PM
katrina's Avatar
sorry did not realise that .
how do I tell witch one I have???
thanks
Old Sep 29, 2005 | 01:02 AM
It will also help if you look at the sticker under the hood and get the engine #'S
Look for a number Like 5244t or something like that.
We should be able to tell which turbo from there Hopefully.
Old Sep 29, 2005 | 01:11 PM
katrina's Avatar
under the hood it says
855r2060170
vin#yv1lw5710r2060170
thanks tec
Old Sep 29, 2005 | 09:32 PM
On the white sticker that is on the hood look for the number like I posted above.I think it is in the engine family on the sticker.
Old Oct 2, 2005 | 10:21 AM
katrina's Avatar
39
3950
60121
hhyffp5
That is all I can find hope this works.
Old Oct 2, 2005 | 12:53 PM
Still not what I am looking for I will see what I can find out.
Also if you can post your Vin #.
Old Oct 3, 2005 | 11:04 AM
katrina's Avatar
The vin # is yv1lw5710r2060170
The man in the parts store says that they are all the same on 94-95 850 s but he is trying to sell me the part .
He is selling the turbo for $250 do you think that is a good deal?
Thanks
Old Oct 3, 2005 | 08:54 PM
That doesn't sound all that bad.
To bad you couldn't find a turbo out of a 850R!!!
Old Nov 29, 2006 | 01:44 AM
nottacop's Avatar
Sorry to bud in on this conversation but what is the difference, and would I have to get the old 94' 850 turbo wagon's computer reprogramed?
I'm lossing power and can't figure from where? I smell oil burning and its coming from the turbo return line. I think it is the return line.
It is the hose that goes from the turbo to the front of the motor. the joint by the intake is leaking oil and it must be dripping somewhere hot.
What do you think?
Thank you in advance, Notta...
154,000 miles with the original turbo. Just F.Y.I.
Old Nov 29, 2006 | 11:33 AM
robert213's Avatar
MY94-96 850 Turbo is VIN 57 and has TD04HL-15G turbo
MY97 850 Turbo is VIN 57 and has TD04HL-15G turbo
MY95 850 T5R is VIN 58 and has TD04HL-15G turbo
MY97 850 R is VIN 58 and has TD04HL-15G turbo
However, the MY94-95 turbo flange to downpipe is conical shaped. The MY96-97 is straight.
When oil changes are done within proper intervals, our turbo(s) easily last over 200K miles.
If you suspect that your turbo has a problem...
Remove the intercooler pipe between turbo and intercooler. Do you see a thick oil film inside of pipe?
Remove the turbo inlet hose between air filter box and turbo. Do you see oil puddled inside of turbo housing? Firmly pull on turbo compressor wheel. Is there a lot of slop and play in the turbo shaft?
Have your current turbo rebuilt professionally. It shouldn't cost much more than $300. Remember to purchase and install a new turbo oil feed line.
And one other thing... For the price of a rebuilt, your existing turbo housing can be over-bored for a larger compressor wheel, such as -15G, -16G, -16T, or -17C.
Shop and compare...
http://www.forcedperformance.net/
Forced Performance
671 New Hope Road West
McKinney, TX 75071
Phone: (972) 984-1800
Fax: (972) 984-1802
Sales@forcedperformance.net
Rebuild@forcedperformance.net
http://www.turbochargers.com
Turbochargers.com
5410 Burr Oak Drive
Houston, Texas 77092
Tech Line: (713) 681-1111
Order Line Toll Free: (800) 749-7111
Fax: (713) 939-1111
Email - Turbo@turbochargers.com
http://www.dallasturbo.com/
Majestic Turbochargers of Dallas
1000 S. Wildwood
Suite 10
Irving, TX, 75060
http://www.hirschinds.com/
HIRSCH FOREIGN
P.O. BOX 18063
PHOENIX, AZ 85009
Old Nov 29, 2006 | 02:54 PM
JPN's Avatar
JPN
(in reply to nottacop)
Hello Andre,
Greetings from Chicagoland.
Turbo return line does leak from the seal. Take a look at Bay-13 at Volvospeed.com for info & procedure:
http://volvospeed.com/Repair/turborepairline.php
This is one of the lines that is notorious for oil leak. A rubber seal on the engine block gets tired and starts leaking. If this is the case, make sure to install new seal ring, as well as a new gasket that attaches to the bottom of the turbo. For the seal ring, I put some oil-resistant high-temp liquid gasket material on the ring and the flange on the pipe and it worked very well. This procedure is easy, but you need to lift the front of the vehicle, and if you decide to do it yourself, make sure to use ramp/jack stands for your safety.
If it's leaking from the oil cooler hose that attaches to the intercooler (Pax (right) side), you may need a new hose assembly or just new seal ring + O-ring + may be a new retainer as well (old retainer can actually be recycled, by pinching it with regular hose clamp). If the hose is leaking from the seam where it is crimped to metal tube, then you need a new hose assembly. If it's leaking from the connection to the intercooler, you only need the seal ring & O-ring.
Slight leak on the bottom of the turbo is normal, even a Volvo dealer tech told me that it's normal and there is not much they can do.
Best wishes,
JPN
Old Nov 29, 2006 | 03:01 PM
JPN's Avatar
JPN
Hello Katrina,
It may be too late to reply by now, but as for the engine ID, it is on the timing belt cover (the black plastic cover attached on the passenger-side of the engine). As Mr. Tech noted, it starts with an alphabet, then followed by 4 digits, then "T" if the engine is turbocharged. I drive 1994 850 Turbo T5 and my engine is B5234T.
Best wishes,
JPN
1Gray760T
Nov 13, 2009 08:19 PM
hubmachine
Feb 21, 2007 10:06 PM
JPN
Oct 12, 2006 08:55 PM
ALJOSEPH
Jul 14, 2006 02:09 AM
