Replacing a Half Shaft
Old Feb 16, 2011 | 01:38 PM
02VolvoS40's Avatar
Question Replacing a Half Shaft
Hello all,
I am possibly looking to replace my half shaft axle and didn't really find anything as detailed in the S40 forum as this sticky from the S60 forum:
https://volvoforums.com/forum/volvo-s60-v60-10/s60-front-hub-axle-replacement-worthy-sticky-46937/
Does all that apply to my '02 S40 as well? Or are there some extra steps in there (or even missing steps) when compared to changing it on my '02 S40?
Old Feb 16, 2011 | 06:09 PM
fcpgroton's Avatar
Former Sponsor
Nope, that is basically it.
Old Feb 17, 2011 | 02:27 PM
02VolvoS40's Avatar
Excellent... Thank you!
Old May 23, 2015 | 05:48 PM
MReed59's Avatar
Default LH Half-Shaft will not "pop" out of tranny
Originally Posted by 02VolvoS40
Hello all,
S60 Front Hub and/or Axle Replacement (Worthy of a sticky?) - Volvo Forums - Volvo Enthusiasts Forum
except for 1 thing
Code:
LT axle: Using pry bar, apply pressure to "pop" the axle free of the
transaxle. There is an internal "C" clip that retains it in the
transaxle. Then withdraw axle from the transaxle, being careful
not to damage seal.
I can not get it to "pop" out of the transmission. I have yanked on the half-shaft so hard the CV joint popped apart. I have rotated the shaft by small degrees prying as I went, I've beat on the pry-bar with a hammer, I've positioned it so I can push on the pry-bar with my legs. It just ain't commin'.
Anyone have any ideas? I can see the circ-clip on the new drivers-side half-shaft. How on earth do you get it out?
2003 S40
-Matt
Old May 23, 2015 | 09:59 PM
pierremcalpine's Avatar
Hang in there it WILL come out. Yanking or pounding won't work though. You need to exert steady pressure so that the c-clip has a chance to compress. I killed myself using a traditional pry-bar and it would not budge. I then tried with roofing pry bar sticking the short end in between the trans and the axle and applying pressure to the long side. Had it out in 60sec. See the following Robert spinner video for a visual of what I mean. He used the same pry bar.
http://youtu.be/9f14N5Tl9Hk
Tdog
Apr 19, 2011 10:39 PM
Tdog
Dec 4, 2010 05:40 PM
FlyBoyd
Mar 28, 2010 03:23 AM
65mustang
Feb 28, 2010 08:14 AM
Latinrolling
Apr 17, 2008 06:50 PM
