Replacing the rear disc brake 01model
Old Oct 1, 2006 | 07:10 PM
kasios's Avatar
Default Replacing the rear disc brake 01model
Hi all,
I'm helping a friend to replace her brakes but I'm stuck. I've replace many brakes before, but I've never encountered this problem. In the instructions, it tells me to "rotate the brake piston backward", but when I try doing it, it won't budge. I tried using a dsic brake pad seperator but it still wont work. Is there a trick to or a step I forgot to do? I'm sorry if I'm not clear enough, beause my English isnot that great.
Thanks.
Old Oct 1, 2006 | 10:06 PM
Default RE: Replacing the rear disc brake 01model
What year and Model is it?
I knwo it isn't an S70 because they were not made in 2001.
Old Oct 2, 2006 | 01:01 AM
kasios's Avatar
Oh Sorry, wrong forum. It's a S40.
Old Oct 3, 2006 | 08:40 PM
OK I moved it to the S40 forum.
You will need a tool that turns and pushes the caliper at the same time to get it to compress.
AlanT
May 22, 2011 01:43 PM
wmpopper
May 28, 2010 11:01 AM
chef
Jan 27, 2010 05:25 PM
Goldfish
May 2, 2008 09:01 PM
kasios
Oct 2, 2006 01:01 AM
