Rubber strut insulator
Old Mar 27, 2016 | 04:05 PM
Herebrooks's Avatar
Default Rubber strut insulator
I'm changing the rear strut in my 2000 S40 and have beentrying to find the lower rear rubber insulators for the struts. Any suggestions? Is that what they are called or coil spring insulators? or something else.
Thanks
Old Mar 27, 2016 | 06:24 PM
the spring insulator (PN 30875136) is a rubber piece that fits into the strut mount. Its a rubber ring about 1/2" tall that has ribbing to fit into the mount. Word of advise - before you pop the old insulator out of the mount, mark the alignment of the slot for the end of the spring to the mount to make sure the the bottom/top of the springs flush up and retains the alignment to the bolt holes when reinstalling.
Old Mar 30, 2016 | 06:48 AM
Hudini's Avatar
The 2000 was a one off year for many systems, suspension being one. Be careful when ordering that you get the correct year. I believe there is a conversion kit to make it like the 2001-2004 models.
Old Mar 30, 2016 | 08:58 AM
right, the 2000s had an old design for the front strut mounts (so the pistons are a different size) - the rears are the same as the newer model.
nhadoulis
Mar 2, 2014 10:03 PM
RJSV70
2001-2013 model year V70
Dec 6, 2012 06:10 AM
cudavid
Jan 3, 2008 09:04 PM
go2sharks
Jun 2, 2007 11:00 AM
jktiffin
Oct 11, 2006 04:10 PM
