S40 2.0T Misfire
Old Dec 25, 2007 | 11:27 AM
khany1's Avatar
Default S40 2.0T Misfire
Hi,
i just purchased my first volvo, but it seems have a misfire, i changed the coil and lead on cylinder 2 and 3 and changed the spark plugs aswell, no real difference,
so then i got a compression test done on all cylinders, cylinder 3 failed, the mechanic told me it's most likely a damaged valve, and told me its gonna be very expensive,
anyone have any ideas,
car is 1998 S40 2.0T SE,
any help appreciated,
Cheers
Old Dec 25, 2007 | 04:37 PM
Default RE: S40 2.0T Misfire
What were the compression readings?
Old Dec 25, 2007 | 08:29 PM
Hudini's Avatar
As tech asked, what are the exact readings? As I understand it, your readings should be within 70% of each other. And, if it is a bad valve, do you have any recourse with the previous owner or garage?
Old Dec 26, 2007 | 04:19 PM
khany1's Avatar
just come back from the mechanic, he removed the head, there was a damaged valve, and now i need to repalce the valve and get the head skimmed and pressure tested, and them buy a head gasket set etc, which is costing alot!
i have located another engine from a 2000 T4, will the engine be a straight swap? (from what ive read, the t4 uses a different turbo and runs at a higher psi, but the gearbox is the same)
will it fit in with my original turbo and is there anything i need to consider(wiring loom, ecu)?
My Engine: - B4204T
T4 Engine: - B4194T
Any help appreciated
Old Dec 30, 2007 | 10:34 AM
Hudini's Avatar
You may be exploring virgin territory here. Anyone in the UK that can help this gentleman?
topherwv
Sep 17, 2009 10:44 AM
rgmendoza
Mar 13, 2009 08:39 PM
FLENG2008
Mar 17, 2008 09:40 AM
hwy9rnr
Feb 22, 2005 10:54 AM
