S40 2007 SE electrics?
Old Apr 29, 2022 | 03:51 AM
helifletch's Avatar
Default S40 2007 SE electrics?
Hi thanks for welcoming me to the forum.
I have a problem in that when I’m driving I get a limp home mode although everything appears normal, then today I’m getting a seat belt warning and airbag caption as I drive even though I’ve reconnected the seat belt and all other seats are empty. At one point windows would not change position.
I’ve been to a local parts shop who have confirmed the battery is ok and so is the charge/alternator……has anyone else had similar or maybe know what the problem could be?
Old Apr 29, 2022 | 07:12 AM
Your first step would be to scan all the control units in the car - and consult a wiring diagram, then develop a rational diagnostic plan from that information. Comprehensive scan tools can record why the air bag light is on.
Old Apr 29, 2022 | 11:38 AM
habbyguy's Avatar
The SRS can get out of whack if you disconnect parts of it while the battery is connected (or reconnect the battery while SRS components are unplugged).
You won't be able to clear that fault with a regular OBD scanner, but there are Volvo-specific scanners that do have the ability to reset an SRS fault. Probably cheaper than a trip to the stealership to do the same, too.
The window isn't related. If it is working now, pretend it never failed. ;-)
Old May 1, 2022 | 04:57 PM
helifletch's Avatar
Thanks guys for the advice much appreciated, wiring diagram maybe a step too far for me I’ll see how it goes. 😉
arditshehu92
Feb 8, 2019 02:40 PM
Calvin2376
May 2, 2011 06:55 PM
Bill Putko
Jun 23, 2009 11:10 AM
2007~S40~2.4i
Mar 29, 2007 01:02 AM
oddferkout
Sep 5, 2006 05:35 PM
