s40 brake caliper
Are you familiar with a banjo bolt? Your brake hose is held to the caliper with a banjo bolt that allows fluid through it. It also has copper washers. You simply unscrew the bolt holding the brake hose to the caliper. You will need to clean it before reattaching. The leaking brake fluid tends to wash dirt onto the previously clean sealing surface.
michaeltroy
02-16-2015 08:43 AM
Jomo1994z71
01-28-2008 09:05 PM
