s40 cold idle
Old Jul 15, 2014 | 05:02 AM
Johann kern's Avatar
Exclamation s40 cold idle
I am a new owner of a volvo S40 2000 model my volvo will not idle when it is cold need to hold the accerator in for about a minite or two bofore it idles do anyone know wat the problem might be
Old Jul 15, 2014 | 06:46 PM
difflock54's Avatar
Could be the throttle body needs cleaning or possibly a faulty maf.
Get the car checked out for stored fault codes to give some more specific clues.
May be due to a number of possible issues.
Old Jul 23, 2014 | 06:15 AM
Moved from "New Member" to S40.
Old Jul 29, 2014 | 01:38 PM
Hudini's Avatar
Does it take a long cranking time to start? Suspect the fuel pressure regulator. Check with a pressure tester. The fuel pressure should hold for a long time after you shut off the engine. It should never go to zero as soon as you turn off the key.
Dennis Bor
May 30, 2011 11:14 AM
leomice
Nov 12, 2010 01:50 PM
lackndt
Nov 4, 2009 10:05 PM
Keilah
Sep 16, 2009 09:35 AM
ss~zoso~ss
Jan 12, 2009 04:27 PM
