S40 electric problem
Old May 29, 2014 | 01:48 AM
frostbyte's Avatar
Default S40 electric problem
Hello everyone...!
I put key into ignition and no reaction.Dashboard dead,steering blocked.So car pulled to nearest service (not authorized one).Checked battery (10 years old) OK,fuses OK.But one relay belong to ignition was hot.So replaced by new and nothing.Replaced by old one and dashboard working,attempt to start engine successful but...windshield wiper always on,remote control with no reaction to stop and error code SRS AIRBAG SERVICE URGENT (never before).Under this relay was smell of something burned.So, according to this mess electrician concluded that BSI CEM MODULE (fuses box ) is damaged and only way to solve this is replace it by new or used one.I called to official dealer and it cost 770 € (used about 120 €).Now i have a question.Can i use used CEM MODULE?I suppose all computers in car are connected.Will it work?So what to do now?
Im done
s40 2004 2.0D
Old May 29, 2014 | 01:40 PM
mf70's Avatar
Was this diagnosis based on a DiCE / VIDA scan by your electrician?
My first reaction to hearing "no reaction.Dashboard dead,steering blocked" is low battery. Even if your battery is in excellent health (which a 10 yr old battery is VERY unlikely to be), if there is corrosion under the clamps, voltage at the Central Electronic Module (CEM) can be low enough to give the central brain of the car fits.
The SRS code will need to be cleared through VIDA even if there is nothing wrong. The SRS flag was probably set due to the single low voltage bad bootup event.
As far as using used parts, I bought and installed a used instrument cluster (DIM). It operated well, aside from retaining its donor car's odometer setting and engine service interval settings. According to VIDA, I should have re-programmed it. The DIM is far less central to the car's operation, however.
I don't think that putting in another car's CEM will actually hurt anything, but I hope not to have to make the experiment myself!
Old May 30, 2014 | 01:53 AM
frostbyte's Avatar
Thanks for your reaction!
Electrician dont have vida,only bosch diagnostic. In CEM are some of the chips burned so i guess there will be needed a new one.i really dont think used one will help according to things was spoken to me: every module is coded to each single car.
Any advice before i will pull car to authorized dealer for good (it will cost too much as well ) ?
Old May 30, 2014 | 07:03 AM
Andrea Bichael's Avatar
I think it will be better to choose the new one and replace the old battery. Because, you can adjust with some other parts. But, battery problems will always be a biggest barrier for a EV user or any vehicle users. You should try with a new battery and replace the old one. This will help you also for a good running of vehicle and there will be no starting problems.
Old May 30, 2014 | 07:22 AM
mf70's Avatar
+1 what Bichael said.
There are some Volvo specialty shops that have paid for the subscription to the Volvo database that can do the everything needed, including software downloads.
If you are at all DIY, Chinese DiCE / VIDA setups are available that can do SRS resets, detailed Volvo diagnostic trouble codes, and 80% of other electronic interventions. You can get a VMware image of a VIDA install for free which will give you the same service information the dealer has.
And, when you change that battery, clean all the connecting surfaces. (Ask my how I know.)
Old Jun 16, 2014 | 06:06 AM
frostbyte's Avatar
Good news! Car woke up from coma! They put used ECM. From my ECM took chips to used one.After that programed with vida and its working.But car has low grip.So EGR is need to be checked.
Also new battery is in.
Old Jun 16, 2014 | 08:04 AM
mf70's Avatar
Thanks for adding the conclusion. What sort of service center was this? Surely not a dealer: "From my ECM took chips to used one. After that programed with vida". In Maryland, Herb Gordon would only have replaced the ECM for untold gold.
Whoever it is deserves recognition.
Old Jun 16, 2014 | 08:18 AM
frostbyte's Avatar
It was not authorized dealer.They told me it will cost about 900€ (in authorized dealer).
Old Jun 16, 2014 | 08:28 AM
mf70's Avatar
That sounds about right. If they aren't trying to stay hidden, why not share the name? If they really did do reprogramming, they must have a Volvo subscription, and they need other customers like you to pay for it!
Old Jun 16, 2014 | 08:36 AM
frostbyte's Avatar
Its one of Bosch services in Slovakia.But main work with ECM module was done by their external team-mate who have vida dice diagnostic.
Old Jun 17, 2014 | 12:05 PM
frostbyte's Avatar
Egr was cleaned and its worked.But after second start again no acceleration.Diagnostic shows something wrong with gas pedal.I cant reach 3000rpm...
Old Jun 25, 2014 | 07:39 AM
frostbyte's Avatar
After replacement of gas pedal, car is working perfectly!
Old Jun 26, 2014 | 07:22 AM
mf70's Avatar
Sounds like you found a good set of mechanics!
When I get fed up with my dealership in Maryland, USA, I guess I'll have to take my V50 to Slovakia.
Old Jun 26, 2014 | 07:59 AM
frostbyte's Avatar
Yes, ur welcome! But prepare for long time holiday.I was one month without car.Its not sounds great,after all im happy now
Underforte
Jun 20, 2013 08:13 PM
740-TURBO
Sep 19, 2011 08:10 PM
codynidaho
Jun 6, 2011 10:02 AM
bmac
Apr 28, 2011 05:40 PM
Kruspe31
Feb 27, 2008 08:53 PM
