s40 fuel rail is stuck and won't come off (pulled as hard as I can)
Old Sep 3, 2018 | 01:31 PM
tobo's Avatar
Default s40 fuel rail is stuck and won't come off (pulled as hard as I can)
Trying to replace injector in cyl 3 to fix missfire.
I have all the retaining screws out and removed a screw and black clip from the fuel line to the rail. I tried to pry it out with a flat screwdriver but I'm scared of breaking something.
I unplugged all the electrical connectors to the injector, fuel pressure sensor, etc. I even removed all the little yellow U-clip on each injector
I tried pulling the fuel rail out as hard as I could and it will not come out. What am I missing ?
2006 volvo s40 inline 5 non-turbo
Since I've removed the screw and clip, do I need to use a screwdriver and pry off the fuel line from the fuel rail?
Old Sep 4, 2018 | 01:09 AM
tobo's Avatar
after taking a break. I didn't get an answer so I went back and just pulled and wiggled and it finally came out.
Old Sep 5, 2018 | 11:30 PM
Hudini's Avatar
It knew you meant business!
Old Sep 6, 2018 | 11:42 AM
pierremcalpine's Avatar
Wel if it's any consolation I ended up having to stand up on my engine to pull mine off many years back when I did my PCV. I then had a devil of a time getting it back on with aftermarket O-rings and ended up giving up and fishing through my garbage to find and re-use the original Volvo O-rings. I'm sure I'll pay for that someday...
ahughes05
Mar 19, 2018 05:24 PM
Galaxy850Sunny
Jun 23, 2014 04:56 PM
no1pony
Oct 10, 2011 09:15 PM
samtheman77
Dec 21, 2009 10:15 AM
evyllp
Dec 3, 2004 10:31 PM
