Fuel rail spacers (uppers)
Old Dec 19, 2009 | 06:27 PM
samtheman77's Avatar
Default Fuel rail spacers (uppers)
Hi all,
I had to change the fuel pressure regulator on my 94 850 turbo today. I was very careful prying the injectors up but lost some of those spacers in the upper part of the fuel rail (still have all the O rings). I went to the parts store to try to get a match but the original is a soft rubber that looks like a grommet. The proposed aftermarket looks like a hard plastic washer. Not sure if this will work anyone have any experience with this? I dont want them leaking.
thanks in advance.
Old Dec 19, 2009 | 06:39 PM
frustrator-bolt's Avatar
I made the same mistake when working the fuel rail. It actually pivots (rotates upwards) in place after you remove the bottom end of the fuel injectors from their sockets. I was lucky and found some on a junker at a local yard. Volvo wants $$$ for each one needed so you can try the ones from the parts store but really check hard for leaks after you reassemble the fuel rail.
Old Dec 20, 2009 | 06:19 AM
sconeman's Avatar
you can reinatall the injectors without them if you need to. If you want to replace them and have time to wait, FCP groton has them listed for $1.75 each.
Old Dec 21, 2009 | 10:15 AM
fcpgroton's Avatar
Former Sponsor
They are actual 1.49. Here is the link.
1993-1997 Volvo 850 Fuel Injector Spacer-Upper
chachouu
Apr 30, 2015 10:47 AM
kkzdad
Mar 19, 2012 12:48 AM
MHUSTON
Dec 13, 2007 06:45 PM
S70driver
Mar 26, 2007 05:50 PM
edahlgren
Oct 7, 2005 09:53 PM
