Fuel line leaking at injector rail
Old Sep 27, 2011 | 06:16 PM
no1pony's Avatar
Default Fuel line leaking at injector rail
So after a few weeks of hard work I am finally done rebuilding and installing the head on a 2003 S80. I am ready to start the car but the fuel line is leaking badly at the little green and black connector. I was very careful when disconecting this but I feel like it is missing an O ring or something. I have checked Vadis but not much help there. Does anyone know if there is an O ring here. ANY info would be greatly appreciated.
Thank You
Old Sep 29, 2011 | 05:56 PM
FASTER's Avatar
check down the line thats the male end,,should be a plastic type of clamp that clips the male into the female part
Old Oct 10, 2011 | 08:54 PM
Lunger's Avatar
on my 2001 s80 there is a green packing that goes on the fuel supply hose going to the fuel rail. I took the intake plenum off to allow me to remove the 2 screws attaching the fuel rail to the intake off. Then I pulled injectors and fuel rail out as assy. this made it easier for me to remove the 4 torx screws that hold the plate on which lock the fuel supply line in the fuel rail. I would suggest replacing the o-ring to the supply line and the o-rings on the injectors. be sure to put petro on o-rings before you install them
Old Oct 10, 2011 | 09:14 PM
Lunger's Avatar
03 2003 Volvo S80 Fuel Line O-Ring - Fuel Delivery - OES Genuine - PartsGeek
this should be the packing you are looking for
Old Oct 10, 2011 | 09:15 PM
Lunger's Avatar
www.partsgeek.com/catalog/2003/volvo/s80/fuel_delivery/fuel_line_o-ring.html
david peters
Dec 14, 2013 11:37 PM
Koriflame
Oct 7, 2011 09:42 PM
tobolate
Jan 12, 2010 10:46 PM
camzaro28
Aug 26, 2006 06:00 AM
edahlgren
Oct 7, 2005 09:53 PM
