S40 Negative Crankcase PSI ????BAD??
Old May 20, 2011 | 09:13 AM
dtower's Avatar
Cool S40 Negative Crankcase PSI ????BAD??
I have a 2004.5 S40 Turbo. I thought a belt was squeeling so I popped the hood and discovered the noise was because the engine is sucking air through the oil fill cap. It pulls so hard it was hard to pull my hand off from over the fill hole? The car is running fine? Just turned 105K hyway miles. Has anyone has this problem, is it a Turbo issue?
Danny
Old May 20, 2011 | 09:57 AM
hammer1234's Avatar
Default PCV valve?
Do a search on "S40 PCV valve" and you should be able to find info on the extended warranty.
Old May 20, 2011 | 02:58 PM
loai's Avatar
i just changed mine. bought it online
VolvoWholesaleParts.com sells Genuine Volvo Parts
any volvo mechanic can do the job. a dealer would ask for $400
Old May 20, 2011 | 06:19 PM
Mad Matt's Avatar
+1. It's a known problem that Volvo has a recall or extended the warranty on. There is a Chassis break for the warranty though.
Call here to see if you car qualifies...
Volvo Customer Care Center
1 Volvo Drive, Rockleigh, NJ 07647
800- 458-1552
Email: customercare@volvoforlife.com
If not get your parts from the link that loai posted or from Tascaparts.com and find an indie shop to do the work for you.
Old Jun 3, 2011 | 08:29 AM
bernard lefebvre's Avatar
Default Oil filter housing Diaphram
I had the same problem.....commun problem ;
It is the `Diaphram`inside the `OIL FILTER HOUSING`that is punctured.
Must replace the Oil Filter Housing.....
regards
boostnm3
Jan 1, 2011 05:29 PM
lowbeer
Apr 18, 2008 02:14 AM
MagicM1364
Dec 22, 2007 12:02 AM
ko_kidd
Aug 25, 2006 08:53 PM
Nand12
Oct 11, 2005 09:56 PM
