S40 Trip Computer Current Fuel Consumption Problem
Old Nov 15, 2012 | 08:01 AM
mikeeburne's Avatar
Default S40 Trip Computer Current Fuel Consumption Problem
The "Current Fuel Consumption" (can also read "Instantaneous") indicator on my S40 Volvo seems to be problematic. The fuel consumption indicated seems to be all over the place, some times reading as high as 45 - 50. Even when stationery it can read 12. What causes this and is it something I should be concerned with. I do not seem to be using excessive fuel and the other indicators, "Average Fuel Consumtion", seem to be working fine.
Old Nov 15, 2012 | 11:25 PM
Willvo's Avatar
That's normal. Your instantaneous fuel consumption in a modern car is nowhere near constant. When coasting on the brake, you will often use no fuel as the motion of the car keeps the engine turning. When accelerating it will drop down to just a few MPG. Mine varies anywhere from 6-99MPG in stop-and-go driving. The average consumption is a much better measure of the engine efficiency.
Old Nov 16, 2012 | 12:24 AM
mikeeburne's Avatar
Thanks. That's is good news. I was worried something was about to go wrong.
Old Nov 16, 2012 | 12:46 AM
The thing about the instant reading is to show you what your getting at the moment. The trick or goal is to keep that number as high as possible at all times. You can turn it into a game and increase your average mileage as high as 20%.
Old Nov 16, 2012 | 02:43 AM
Willvo's Avatar
It can help a lot in learning to have a light foot - you can learn how little throttle is needed to maintain a given speed and easily gain 3-4 MPG.
Just remember to look up at the road occasionally!
john3-16
Nov 27, 2012 06:55 AM
kentaur9
Aug 1, 2012 04:50 AM
slsnumber1
Mar 15, 2011 02:55 PM
Steamroll9
Feb 24, 2008 04:58 PM
edgoss
Sep 18, 2007 09:59 PM
