S40 Upper head/Camshaft cover
Old Apr 16, 2013 | 07:08 AM
johncecil's Avatar
Default S40 Upper head/Camshaft cover
Hi, I'm a Volvo newbie, and I'm hoping for some help.
I've pulled the camshaft cover off and cracked it in the process. (Yeah, I know what youre thinking and you're probably right))
Question is, Can I replace it with another, or are they matched to the cams and lower head?
Thanks John
Old Apr 16, 2013 | 07:15 AM
Hudini's Avatar
As far as I know you can use any from the same type engine.
Is it cracked in such a way that you can't TIG weld it?
Old Apr 16, 2013 | 07:23 AM
johncecil's Avatar
Not sure how to explain this.... Up the cam gear end there are some very shiny grooves that the cam sit in (where the seal is) and its the side of that groove that is cracked. I suspect the shiny surface won't ake well to the welding. Any ideas greatly appreciated.
Cheers John
Old Apr 16, 2013 | 07:35 AM
ES6T's Avatar
They are machined to the head and should not be used with another head
Old Apr 16, 2013 | 08:05 AM
johncecil's Avatar
Thanks
Uh -oh, where do I turn now?. New lower head as well?.. Could be goodnight for my S40
Old Apr 16, 2013 | 08:14 AM
ES6T's Avatar
Yes, you would need the whole head. Can you upload a pic of the damage?
Old Apr 16, 2013 | 08:42 AM
johncecil's Avatar
Hi ES6T, I'll have to get a pic tomorrow. How can I send it to you (I'm a newbie to this forum thing)
Cheers John
Old Apr 16, 2013 | 09:09 AM
ES6T's Avatar
You'll have to upload it to a file sharing site and post the link. Not sure if there is a direct upload link on the forum, I'm using the mobile version.
Old Apr 16, 2013 | 06:37 PM
Hudini's Avatar
Is this the 1998 S40? European model?
Old Apr 16, 2013 | 11:38 PM
johncecil's Avatar
Yes it is, although delivered in Australia.
Cheers John
Old Apr 17, 2013 | 07:55 AM
johncecil's Avatar
Hi
These are the pics of my broken camcover. Any thoughts?Volvo Forums - Volvo Enthusiasts Forum - johncecil's Album: Upper Head/Camcover
Cheers John
Old Apr 17, 2013 | 08:04 AM
ES6T's Avatar
That may be weldable. I had a customers car who brought it in because an independent shop resurfaced the head and the cam seals were leaking. They replaced the can seals twice but they say all leaked. When I got it apart I found they had cracked the head in the same area, though not fully broken. Sent it to a machine shop who was able to weld and polish it and it was good as new.
Yours is a little different because it is broken off fully, but its worth having someone look at to see if they can weld it.
Old Apr 17, 2013 | 10:18 AM
migbro's Avatar
Originally Posted by johncecil
Hi
Cheers John
Looks like that camcover was fabricated from sintered (powdered) aluminum then machined. You pulled up on the opposite end right? The problem with sintered metal is that it has a highly granular structure and is very poor in tensile stress.
It's an old car, so might be worth trying something unconventional. I don't know exactly what sits at that location but it looks as though that's a recess for a seal? The sealing surface is intact so if that were my car I'd try an epoxy fix. The broken sintered metal has a large surface area so is quite suitable for gluing. Get the broken surfaces as clean as you can with acetone, then use JB Weld or something similar - a high strength two part epoxy.
If this doesn't seem like a great idea, think about the fact that the epoxied repair will probably then be stronger than the metal on either side of it. Yep, I'd try it.
Old Apr 18, 2013 | 12:30 AM
johncecil's Avatar
Hi,
Here's the link to the damage. Do you think it will survive....or is it 'good night nurse'?
Cheers John
Old Apr 18, 2013 | 04:47 AM
Hudini's Avatar
Just replace it with a junkyard one.
Old Apr 18, 2013 | 07:19 AM
migbro's Avatar
As ES6T has already pointed out, the camcover is line bored to the head. So you can't replace the camcover alone.
Old Apr 18, 2013 | 08:02 AM
  #17
ES6T's Avatar
Hi,
Cheers John
See my post above- it might be weldable.
Also, I forgot to mention that part is not really a sealing part. It holds the camshaft from moving in and out. If you notice, there is a similar part in the head half and as long as that is still in tact, it would probably be enough to hold it even with no repair to the cam cover.
Old Apr 18, 2013 | 08:13 AM
  #18
Hudini's Avatar
I would try it before spending a ton more money on a matched set. Given the previous Volvo engines I've worked on I would bet the tolerances are close enough.
Old Apr 18, 2013 | 09:08 AM
  #19
ES6T's Avatar
You could try it, but it could wipe out one or both cams so that's a risk.
I'd look into having it welded and polished first. And if that's not an option, you could put it back without that broken piece, as long as there are no sharp edges that could damage the cam or seal.
Old Apr 18, 2013 | 10:05 AM
  #20
migbro's Avatar
Yeah, I thought that too. There's enough of the sealing surfaces still intact.
awfulwaffle
Nov 9, 2013 11:57 AM
ThomasK
May 3, 2013 10:56 PM
midnightmechanic
May 17, 2012 10:15 AM
JHudson
Jun 21, 2010 04:04 PM
ebrobb
Aug 10, 2006 08:25 PM
