2000 s40 ABS
Old Apr 16, 2013 | 12:10 AM
Keith Joubert's Avatar
Exclamation 2000 s40 ABS
Hi all,
I have a s40 2000 model , i have an ABS issues. the abs light comes on when the car gets hot and the speedo stops working , the scan tool checks the system 100% no issues but only when cold. I have found that when hot we cannot get a reading from the brake system on the computer, i did go through a very bad and deep patch of water during bad weather one day. please any help would great.
Old Apr 17, 2013 | 05:43 AM
Hi Keith, welcome to the forum.
Have you tried to do anything to trouble shoot the problem? Checked the sensor wiring or anything?
Old Apr 18, 2013 | 05:20 AM
Default abs,
hi thanks for the reply,
I changed sensors in the front ,swoped the modulator and pump with a second hand one but no change , same story sam issue no change.
I am going to double check with a diffrent modulator again maybe the other also faulty. were does the abs wires lead to in this car ,maybe wire fault but how.. bad earth...
Old Apr 18, 2013 | 01:54 PM
Default abs
Problem solved , ABS Module RIP . case closed.
mt6127
Feb 4, 2015 10:32 PM
J Dubb
Jun 25, 2011 08:11 PM
marcello1965
Jan 24, 2010 04:25 PM
paulh
Jan 30, 2008 08:22 PM
robohopar
Sep 27, 2007 11:37 AM
