S40 Valve bucket shims
Old May 20, 2016 | 07:54 PM
Nismou20's Avatar
Default S40 Valve bucket shims
So I'm removing the head off a 2.4i 5 and when I flipped the head over after removing from the block all the buckets fell out. I don't know which respective bucket goes to which valve. They are numbered differently. There's about 6 different numbers. 1602,1604,1606,1608,1610 and 1612. Does this mean they are all different thicknesses? All intake valves look the same just as exhaust. How do I match these up now? Am I in a world of S--t?
Old May 20, 2016 | 09:33 PM
ES6T's Avatar
Yep, they are different thicknesses. There is a special tool to hold the cam on so you can measure the valve clearance and then calculate what size you need.
Old May 20, 2016 | 10:02 PM
Nismou20's Avatar
So with 6 different thicknesses they set from factory? So I would have to somehow hold down cam in journals while turning the cam and measure the needed clearance for each bucket to cam?
Old May 20, 2016 | 10:08 PM
ES6T's Avatar
Yours was set with 6 different thicknesses. There are a lot more than that available.
You'd have to go through the whole valve adjustment procedure, which I don't have with me. Hold the cam down with two lifters in place. Measure clearance. Compare to specs and calculate the size of the lifter you need. Since you have the lifters that came in there, you'd probably have to calculate the range that can be used for each valve, and then compare with what you have.
Or take the head to a machine shop with the lifters and have them do it.
Wesley brown
Jan 4, 2015 08:10 AM
rickt
Jul 22, 2013 09:19 PM
analogies
May 5, 2013 02:01 PM
MC92
Feb 10, 2012 10:06 PM
Miatamon
Apr 11, 2007 03:38 PM
