S40 won't start
Old Feb 22, 2006 | 11:52 PM
bmac8369's Avatar
Default S40 won't start
Just bought a 2000 S40 T. Car is in great shape has 90K miles and previous owner had all the service records. Went to start it and nothing happens. All electronics are on and has plenty of juice in the battery but wont try to turn over the engine. Then finally after about 10 mins and 20 tries the engine finally turned over and started right up. Could this be the starter or some kind of other problem. Please help!!!!!!
thanks
brett
Old Feb 23, 2006 | 12:27 AM
Default RE: S40 won't start
Try to get it to act up again. If it does test for power at the starter on the small wire then the key is in the start position.
Old Feb 23, 2006 | 07:18 PM
gordon368's Avatar
that happened to me, I got it to start after lots of tries, it started finally, overheated, coolant sprayed everywhere, and i eneded up neading a coolant sensor, thermostat and gasket. after market place charges about 380$ for that....
Old Mar 8, 2006 | 07:04 AM
trlnlty's Avatar
ORIGINAL: gordon368
oh man that sounds like the problem i might have.l
have a 2000 volvo.
my friend who drove it the other day told me that the car would rev for no reason when the car was idling... also the car couldnt start at one point of time.. i said i'll look into it.
so today i drove it somewhere and i realised first thing that the car was somehow driving itself .. like it was on cruise control. when i lifted on the trottle the rev counter would stay at 2.5k rpm .. when i came to a stop light the car did the same thing and revved HIGH .. like to 4k rpm when i shifted it to neutral .. also the engine temp shot all the way up .. when i shifted to D again.. the rpm came down and the temp also .. but this time went down to COLD .. and stayed that way.
Later on.. i reach my destination and finished my stuff, i couldnt start my car after that.
I popped the hood and looked at the (+) terminal and it was all corroded.. lots of gray/silver stuff around the terminal. I cleaned it with some armorall wipes (all i ahd at the time) but it didnt help, car still wouldnt start. It would crank and crank like it needed just a little more. I tried to jump start it but it wouldnt work as well.
I left the car there and got my friend to pick me up.
anyone have any ideas on what the problem might be? Funny thing is that the car remote system works, like i can lock/unlock the car perfectly.
Old Mar 8, 2006 | 01:58 PM
gordon368's Avatar
thats samething I experienced, it would accelerate on its own and the engine temp would go way up and then come down!, also the engine temp would go all the way up and down for me too. Well if it Idles too lonng the coolant will spray everywhere, it was funny, because I just brought it into the mechanic they were puzzled. They popped the hood and were looking for something wrong but couldnt figure it out. Then after sometime of looking, the coolant sprayed and it was cool. Smoke came out, and they shut my car off and put some water on the coolant area to open it up and put some more coolant in their.
I betcha its the coolant sensor, thermostat and gasket.
That was the last problem I encountnered, then I sold that car and bought a 2001 s80 t6, havnt had to pay for anything for it except the 600$ 30k major maintainence.
Old Mar 8, 2006 | 02:51 PM
trlnlty's Avatar
ORIGINAL: gordon368
do you have a ballpark how much is that going to run me? do i have to go to volvo to get it fixed?
Old Mar 8, 2006 | 08:34 PM
ORIGINAL: trlnlty
ORIGINAL: gordon368
If you install it your self about $150.00 or so.
That gets my Vote as well. The coolant temp sensor and thermostat.
Old Mar 9, 2006 | 12:39 AM
gordon368's Avatar
it ran me somewhere between 300-400 from a gas station mechanic, he said that volvo would charge twice as much....
Old Mar 10, 2006 | 10:28 AM
ZIGZAG's Avatar
I am thinking this should become a recall maybe, you are telling me the engine revs and maintains power when you take you foot off. Hummm that sounds kinda dangerous.
Old Mar 12, 2006 | 08:10 PM
vollic's Avatar
I have tthe same problem with my 2000S40.The RPM will rave to around 3000rpm always when the A/C is switched on and after will slowly return back to normal (1000 rpm).It always happens when the A/C thermostat starts to regulate the cabin air temperature (i can hear a 'bong' sound)and with just a light tab on the accelerator the RPM will rave to around 3000rpm (which should not be).Sometimes the RPM will even rave by its own without tapping the accelerator pedal.During hot climate driving is even worse the car becomes jerky becos of the surge of the rpm and even lost of power.When i release the accelerator pedal when driving the car still moves forward becos the rpm stays at it's last position i.e 2500 rpm.immediately when i switch off the aircon the rpm goes back to normal.In the car i can hear hissing sound for about 5-10 secs when the aircon is switched on and this symthoms repeats.Pollen filters,and idling valve changed,AC gas charged but still persist.
Old Mar 12, 2006 | 10:53 PM
gordon368's Avatar
heh, if you got a speeding ticket, you could say it was the cars fault! what do you think the officer would say to that?
Gustav
Nov 11, 2017 01:01 PM
volvoralph
Jul 19, 2016 04:19 PM
hokiedave
May 4, 2009 12:37 PM
exotek
Nov 11, 2008 09:32 AM
