Smokey
Old Apr 10, 2006 | 01:49 PM
Matthew's Avatar
Default Smokey
sometimes I get lots of smoke when cruising at around 70mph and sometimes during acceleration from 75 through 90 in fifth gear. but then the smoke stops and i can accelerate hard through the revs in any gear with no smoke at all. whats happening, please help
Old Apr 10, 2006 | 10:39 PM
Default RE: Smokey
Any check engine light?
Old Apr 11, 2006 | 07:01 AM
Matthew's Avatar
Default RE: Smokey
No check engine light, recently had a new turbo. it generaly happen at 3000 rpm
Old Apr 11, 2006 | 09:29 PM
androide016's Avatar
Default RE: Smokey
Check for oil leaks from the turbo, this can cause smoke from the burned leaked oil.
Old Apr 11, 2006 | 10:39 PM
Default RE: Smokey
Check all of the hoses off the Vent box really good for clogs.
Old Apr 12, 2006 | 09:36 AM
Matthew's Avatar
Default RE: Smokey
Cheers guys i will check for these tonight and let you tomorrow.
Old Apr 12, 2006 | 11:22 AM
Matthew's Avatar
Default RE: Smokey
I had a look for oil leaks. cant find any. Tech, i dont where to locate the vent box. please advise. cheers
Old Apr 12, 2006 | 09:39 PM
Default RE: Smokey
The Vent box is under the intake manifold on the right side of the car. It is like behind the Alt. and A/C compressor. It bolts to the front of the block.
Old Apr 18, 2006 | 09:17 AM
Matthew's Avatar
Default RE: Smokey
Hi, checked the turbo again for leakage and found a very small amount of oil. not enough to drip to the ground. is this bad. if bad how bad. cheers
Old Apr 18, 2006 | 08:38 PM
Default RE: Smokey
Was it coming from the side by the induction hose?
If so it is normal for you to have a little bit there.
Old Apr 19, 2006 | 10:10 AM
Matthew's Avatar
Default RE: Smokey
It was, does that explain the smoke?
Old Apr 19, 2006 | 08:51 PM
Default RE: Smokey
Not really has the smoke cleared up at all?
Old Apr 21, 2006 | 08:50 AM
Matthew's Avatar
Default RE: Smokey
I has seemed to clear up recently. I will be doing some miles over the weekend so I will give you somemore feedback monday.
Old Apr 25, 2006 | 10:37 AM
Matthew's Avatar
Default RE: Smokey
hi tech, it has cleared up. what could have been causing it. is it a problem i should get checked out? Cheers
Old Apr 25, 2006 | 08:39 PM
Default RE: Smokey
The smoke might have been oil burn off from the bad turbo.
thejim662
Dec 22, 2010 01:28 PM
zero_cool05
Aug 9, 2009 03:01 AM
oscar moncada
Feb 18, 2006 12:09 PM
