Smokey Volvo
Old Mar 18, 2009 | 04:20 AM
zero_cool05's Avatar
Exclamation Smokey Volvo
Hey folks, I was just wondering, why my volvo (940 se 2.4 turbo diesel) is so smokey. She doesn't burn oil, and fuel economy is very good. (450km with half a tank) But when driving at high revs, there is a lot of black smoke come from the exhaust. also when driving at 50 or 60 km/h in any gear and i push the accelerator all the way, there is a white grayish smoke coming. looks in the rear view mirror a little like its foggy outside. Really would like to know what that might be. Power and acceleration are good. Have a car test next week so i'd like to know if it is bad or not.
Regards
Old Mar 18, 2009 | 12:30 PM
Anyone got any idea?
Old Mar 18, 2009 | 02:00 PM
TIPSP's Avatar
Got Boost?
I thought that all diesels shoot smoke?
Old Mar 18, 2009 | 02:46 PM
tedv's Avatar
The diesel pump needs work-the fuel is not burning properly...
Old Mar 20, 2009 | 05:23 AM
Typhoon's Avatar
Most (all?) non common rail or turbo diesels produce some smoke at full throttle. The pumps are set rich to avoid detonation, which is bad at 22 to 1 compression.......
As long as the smoke is only there at 3/4 throttle plus (at any revs), you can just accept it as normal turbo diesel behaviour. But go ahead and check your air filter too. Intake restrictions will make a diesel smokey.
Have a look at a semi trailer or bus next time it takes off from a stop. Lots of smkoe initially and again at top of rev range.
Regards, Andrew.
Old May 14, 2009 | 07:53 AM
Been to test last week and it passed, so everything must be in order. Thanx for greathelp
Old Aug 9, 2009 | 03:01 AM
dwill130's Avatar
My Volvo S60 D5 53 plate on 80,000 miles was very smokey, but I just had the auto transmission oil flushed and changed, and it seems to have improved! I don't know if its related, but it has made a big difference.
thejim662
Dec 22, 2010 01:28 PM
Matthew
Apr 25, 2006 08:39 PM
oscar moncada
Feb 18, 2006 12:09 PM
