Stuck in park
Old Nov 6, 2015 | 07:49 AM
Asalgado24's Avatar
Default Stuck in park
Hello, my name is adrian and i am new to this forum. I have a 2009 s40 that i love so far. It has 70k miles and no problems thus far until now. I went out to start my car yesterday and i got absolutely nothing. When i stick the key in the ignition all my lights come on in the annunciator, but i get no engine crank, not even a sign that my starter is rotating. The battery checked above 12 volts, and the other tricky thing is that my car is stuck in park, it will not allow me to take it into neutral. If someone could give me some info i would highly appreciate it. Look forward to hearing from yall.
Adrian
Old Nov 6, 2015 | 02:56 PM
LittleMushi's Avatar
Did you check the ground wire?
Old Nov 7, 2015 | 02:20 PM
s40_Ontario's Avatar
Battery or neutral starting switch? use the shift lock button to release the shifter, roll through all the gears, P to Low 5 or 6 times, return to park and try again. The neutral start switch has gone bad, it doesn't know you are in park or N and will not turn over.
Old Nov 13, 2015 | 03:39 PM
Hudini's Avatar
The ignition switch itself is also a suspect. Mine would usually crank if you tried turning the key several times.
Old Nov 14, 2015 | 07:08 AM
pierremcalpine's Avatar
I had this happen to me once last year. Of course it was my wife driving at the time so she took this as ammo to suggest that it was time to replace the car...I also resorted to trying to wiggle the key repeatedly. It finally worked but I am sure that I would have busted the switchblade key doing this. As it was I use the rigid spare key to get the job done.
Old Feb 14, 2016 | 01:12 PM
c.dolman@sympatico.ca's Avatar
We are in sub zero temperatures,my husband just remembered that water was spilled in console. So he now has my hair dryer on high and the heat turned up to try and melt whatever is blocking the tube
caselfridge
Dec 5, 2023 12:33 AM
Obelix
Jun 20, 2022 08:40 AM
TiMa
Sep 13, 2010 02:08 PM
miss ammo
Apr 1, 2010 05:48 PM
Business_Socks
Oct 20, 2009 12:21 AM
