2010 S40 slight idle shudder?
Old Feb 15, 2016 | 10:49 AM
Nismou20's Avatar
Default 2010 S40 slight idle shudder?
My daughter bought a 2010 5 cylinder Na and I've always noticed a slight erratic idle or shudder to it. It drives just fine but wondered if this is normal for a Volvo 5. It just doesn't seem smooth as other 4 cylinders. Is it a design issue or do you think there is a problem? Should it be really smooth? I'm totally new to the Volvo world. Thanks
Old Feb 15, 2016 | 11:11 AM
how many miles on the car? The 5 cyl engines are well balanced so they should be smooth - so I'm inclined to think you may want to check a few things - plugs, coil packs (particularly if the car is getting up around 80-100K miles), air filter, inspect the MAF and throttle body for cleanliness, look for possible cracked vacuum lines or air leaks around the intake manifold (ie spray with cleaner to see if it gets sucked in). Also does it sound like there may be an exhaust leak??
Old Feb 15, 2016 | 11:13 AM
Nismou20's Avatar
Thanks, now knowing it should be smooth, I'll tackle it like any other car.
Mike Hasson
Dec 15, 2009 12:33 PM
casualfc
Jul 11, 2008 12:53 PM
mill_farm
Jul 27, 2007 08:48 PM
gridlockfilms
Jun 2, 2007 08:26 PM
kennys s40
Oct 23, 2006 10:22 PM
