Suspension diagram?
Are you in need of parts?
These are what commonly go bad.
http://www.fcpgroton.com/product-exe...ategory_id/185
The spring goes between that part and the strut.
Thank you, but I'm just trying to understand more how things are connected. The struts, isolators, spring seats, sway bar bushings and sway bar links have been replaced, yet the sway bar has been hitting the control arm. It is now thought it may be the sway bar is slightly bent. This all began due to a knocking up front, so naturally the struts were replaced.
Thank you for the help. It may have been in an accident at some time, and perhaps the sway bar has a slight bend to it. I bought it used in the summer or 2005 so don't have any history, other than I know they didn't keep up on regular maintenance. I had a bit of catch up to do when I first got it.
Saw this is a 2 year old post. But quick question. Were the sway bar bushings the right size to fit the sway bar? There are a number of different sway bars that volvo uses, and they have different diameters, and the bushings are made to hold those diameters. Check the dimentions of the bushings and the part number and match it to the bar you have. If the bushings are too loose, they will not hold the bar in place well even if they are securely fastened to the subframe. Sorry for the very late reply. Just a thought since none of the prior posters mentioned the bushing size issue.
try www.myvolvopartsonline.com
I found a decent rear strut parts diagram there. Maybe they have a front one also.
One of the first things I did when I got my 2000 S40 was replace an endlink with a new one from Moog. Turned out it was just slightly too long even though it was the correct part. It ended up hitting the control arm. I'm not sure how long they actually have to be, (I gotta measure) but I thought I'd throw that out there.
