Tale of two Volvo specialists...
Old Jan 25, 2007 | 11:23 PM
captsupermarket's Avatar
Default Tale of two Volvo specialists...
A Volvo mechanic in Chicago informed me that "Volvo advises against a transmission oil change. Leave it alone if level and color are Ok."
Another Volvo mechanic in LA informed me that "You should absolutely change the fluid or it eventually ruins the disc. Volvo never said not to change the fluid. They said you need a special kind of synthetic fluid."
This was concerning my s40 but also I guess it concerns all the late 90's to present models.
I looked around the web and never found anything concrete.
Any comments?
Thanks!
Old Jan 26, 2007 | 02:36 PM
m4gician's Avatar
Default RE: Tale of two Volvo specialists...
It's never BAD to change your transmission oil. Period, cut and dry. Just like you can NEVER change your oil too much, you can NEVER change your transmission oil too much.
Old Jan 26, 2007 | 04:36 PM
hocbj23's Avatar
My Volvo mech says that Volvo doesnt have a specific tranny oil change recommendation, but he recommends at 60 k which is when I changed mine. BJ
Old Jan 26, 2007 | 05:52 PM
I guess it seemed a bit odd that he would say that Volvo recommends not to change the oil at all. It certainly makes sense to change the oil. I mean it can't be eternally self-cleaning oil.
Old Jan 26, 2007 | 09:20 PM
Volvonut's Avatar
I'd want to change mine around 30-35k. Any idea what synthetic to use and can that be mixed in a drain/fill without a flush?
Old Jan 26, 2007 | 09:32 PM
You need to find out exactly which transmission is in the car first.
Next check out this post.
https://volvoforums.com/m_35817/tm.htm
Old Jan 26, 2007 | 09:43 PM
Volvonut's Avatar
tech thks, good info in that thread
I like to keep my tranns fluid clean.
mphilleo
May 2, 2013 10:48 PM
jbuck
Nov 16, 2011 05:48 PM
joik
North East
Sep 7, 2010 10:56 AM
brutt
Feb 19, 2007 10:39 AM
AshevilleXC70
Aug 21, 2005 01:38 PM
