Thermostat change...
Old Jul 30, 2013 | 06:07 PM
  #21
JJH's Avatar
JJH
Originally Posted by Hudini
It is a standard coolant temperature sensor located in the thermostat housing. Do you have a question about it? Do you have a trouble code? Why are you changing the thermostat?
Not sure I'm going to change it now... But there were a couple times that the temp. went up in my car. Thought that maybe the thermostat was bad but now I don't know. It seems to be doing ok right now.
Old Aug 1, 2013 | 05:05 PM
  #22
Hudini's Avatar
Ok, I see. The computer will throw a code if the sensor goes bad. The code will be specifically for the sensor. There is another code for the thermostat: P0128 code - Coolant Temperature Below Thermostat Regulating Temperature. These seem to be pretty accurate codes in diagnosing issues. If you are not getting a code then look for things like low coolant levels and front mounted radiator fans. Leaves and bugs can block radiator airflow and cause higher temps too.
Stratoblaster
Sep 2, 2024 11:18 AM
jstarman
Nov 9, 2010 06:32 PM
Shaggy2000
Apr 10, 2009 11:52 PM
bc
Mar 12, 2008 06:53 PM
dpsa
Jan 17, 2008 04:32 PM
