tire size
RE: tire size
http://www.discounttiredirect.com/di...amp;vid=005007
Looks like your options from them are...
195/60-15 which you already have.
185/65-15
195/65-15 which is what I run.
205/60-15
Might be more options out there, try TireRack as well.
185/65-15
205/60-15
on
RE: tire size
Well the 65's wont be as low as the 60's you are currently running. If you are wanting lower and wider you would need to go with 205, 215, etc. by 55, 50 etc. Going to a lower profile tire is going to put your odometer off. Plus with a 15" rim you are probably looking at a rim width of about 6.5" so you will need to be careful on how wide you go before the current rims no longer will work.
RE: tire size
ORIGINAL: tecuko
Thank you!
Do you think a little bit flatter, say /55 would be ok too?
I got this Volvo in January, and before that I was driving Imprezas. The suspension is much softer, which is ok, but in curves I feel a hesitation, partly, probably, due to tall tires.
Thank you!
RE: tire size
ORIGINAL: djerikd
I don't see why not...if you like the ride that the lower-profile tires give. However, I personally wouldn't because I don't care for the harsher, more jarring ride that the shorter tires provide. I like the wider footprint of the 205s though.
ORIGINAL: tecuko
Thank you!
Thank you!
_________________
Are you sure on buying discount auto parts?
HummerGuy
10-10-2008 08:02 AM
