transmission drain plug location for s40
Old Dec 3, 2019 | 05:47 AM
dcjcdc's Avatar
Default transmission drain plug location for s40
looking for location of the transmission drain plug for 2002 volvo s40 aoutomatic 1.9 litre
cant seem to find it on the net
thanks
Old Dec 3, 2019 | 11:27 AM
Drain plug is on the right hand side of the casing, below and just forward of the driveshaft (per Haynes ). Should be a 24mm so make sure you have that size and its recommended to use a new seal and retighten to 40NM (30 Ft-Lb)
Old Dec 4, 2019 | 04:48 PM
dcjcdc's Avatar
when you mention right hand side of the casing..if in front of the car,,and you go under car..so it would be on right side of casing transmission..drivers side or casing facing passenger side if going from front of the car..as well im presuming there should only be one 24mm nut...so if i see 24mm nut i found it
thanks
Paul Hahn
Feb 15, 2014 04:18 PM
850R4Ever
Jan 15, 2014 02:53 PM
chrispy960
Jan 15, 2013 02:57 PM
tobo57
Jan 12, 2008 06:37 PM
tobo57
Jan 9, 2008 07:10 PM
