Transmission leak
Old Feb 16, 2008 | 09:15 AM
BubbainGE's Avatar
Default Transmission leak
The wife just came home with transmission fluid pouring from the front of the car. A brief investigation revealed the culprit to be a loose line (click on blue connector) on the drivers side radiator. I have no idea how much fluid was lost, how much it holds, or even where to fill it up or check the fluid level. The owners manual says nothing about the tranny, and the dealership is closed. On the positive, there is no slippage and the loose line fixed the leak. Any help is appreciated.
Edit; The car is an '06 S40 with the geartronix transmission.
Old Feb 16, 2008 | 09:24 AM
Default RE: Transmission leak
You fill through the dipstick tube.
Old Feb 16, 2008 | 09:26 AM
BubbainGE's Avatar
I can't find the dipstick tube. I've been all over this thing & can't see anything that resembles a dipstick.
Old Feb 16, 2008 | 09:33 AM
It is Yellow and usually hidden down under where the lower radiator hose goes to the radiator.
It is really hard to find but it is there.
Old Feb 16, 2008 | 09:39 AM
BubbainGE's Avatar
Okay, I found it. I'm going to take it over to the carwash & get the underside sprayed off before the Polizei come give me a tickett for harming the environment, or some crazy stuff.I'll see if I can get to it over on post. Thanks for the help!!
Old Feb 16, 2008 | 09:47 AM
No problem.
2008XC70
2001-2013 model year XC70
Dec 20, 2017 03:07 PM
jeffrisley
Jun 14, 2015 01:48 PM
ROBLU540
Feb 20, 2009 07:59 PM
1999S80T6
Dec 16, 2008 04:54 AM
tcrossley
Feb 1, 2007 10:49 PM
