Turn Signal Cover Replace
Old Dec 21, 2007 | 12:14 AM
nick61416's Avatar
Default Turn Signal Cover Replace
Got into an accident today[:@]. nothing bad just a dent and cracked my turn signal cover. i see them on ebay for about 30$ so ill prob pic one up. How would i go about replacing this? what the easiest way cause i dont want to bring toa shop if i dont need to.
car is 2002 s40 1.9t
Thanks
Old Dec 21, 2007 | 06:59 AM
jks2's Avatar
Default RE: Turn Signal Cover Replace
Most of them are held in with plastic tabs. You usually just remove the light (most of them twist out) and then snap the old one out and the new one in, then reinsert the light.
Old Dec 21, 2007 | 11:21 AM
Hudini's Avatar
Not sure about the newer model but the 2000-2004.5 have a phillips head screw holding them in place. The screw is located beside the headlight and you get to it by looking straight down from under the hood. Loosen the screw and pull the entire turn signal assembly forward. Do not pull up or out. You will see why when you get it loose. Having broken the little plastic pieces on the back of mine (JB Weld repaired) it is now easy and quick to replace.
Old Dec 21, 2007 | 04:48 PM
billofdurham's Avatar
Loosen the screw
Don't turn the screw more than two turns. It does not need to come out.
Turbo_Boss
May 4, 2022 12:39 PM
Dorion
Jun 26, 2014 10:45 AM
Jkherw
Jun 30, 2013 02:19 PM
crosby1
Apr 15, 2010 08:17 PM
Dewaholic
Oct 9, 2009 11:07 PM
