VIDA error codes that may CMM
Old Aug 10, 2025 | 12:33 PM
matdeinn3's Avatar
Default VIDA error codes that may CMM
Volvo S40/V50, European Edition 1.8L model 2008. Engine Code B4184S11.
Air condition Flaps are not turning from Heat to Cold and vice versa. I manually turn the flaps from the driver's bottom side using a screwdriver from a hole I created, but it isn't an enjoyable job.
So the problem I suspect is that the flaps are stuck. Re-Calibration of the CCM can possibly solve the problem? What are my options here? To disassemble the whole dashboard and try to repair/replace the flaps or the flaps motor itself?I didn't visit any technician until now to get any VIDA error codes that may CMM return. So, can I manually reset the CCM module? How to know if the motor is bad or just the flaps are stuck? Can other ODB diagnostics from a 3rd party manufacturer re-calibrate the CCM module?
Regards,
Old Sep 23, 2025 | 03:19 AM
dhsyu's Avatar
Whenever widespread errors appear, this is the first time you should compare the battery and charging system. What is your battery's reference code?
192.168.100.1 192.168.1.1
Old Jan 20, 2026 | 06:53 AM
sallyromme12's Avatar
VIDA error codes relate to Volvo vehicle diagnostics (like ECM-U210100 for configuration issues or battery problems in mild hybrids), while CMM (Coordinate Measuring Machine) codes, like
Old Jan 27, 2026 | 11:06 AM
richardkonrad's Avatar
So you manually turn the flaps then the flaps work so must be a faulty connection or the motors or more probably broken gears , as turning manualy one can jump a broken gear
matdeinn3
May 31, 2026 07:05 PM
matdeinn3
May 31, 2026 07:04 PM
Georgeandkira
Jan 23, 2024 12:26 PM
kapows
Mar 10, 2022 09:08 AM
vLoke
Jan 9, 2018 02:34 PM
