volvo s40 2002 1.9t4 auto
Old Sep 16, 2019 | 04:27 PM
Ibrahim Åžerif's Avatar
Default volvo s40 2002 1.9t4 auto
hello guys i also need to change my shocks or struts in my car but i dont know which one it has . does it have shocks or struts ? thanks u .
Old Sep 16, 2019 | 05:54 PM
struts refer to the front where the spring is contained by the bottom mount plate directly on the housing and a seat on the top that bolts to the chassis and the strut rod. shocks refer to the rears which bolt to the inner fender top and to the swing arm on the bottom but is not attached to the spring. When replacing the struts in the front you will need a spring compressor to remove the strut mount ie bearing/bushing plates. the rears can be removed directly without removing the spring. Note the front springs on the S40s (at least on my 2000) are very long and not all spring compressors will fit...
VolvoS6013
Sep 17, 2019 08:20 AM
gfuller40
Feb 28, 2014 11:29 PM
Jared98112
Nov 7, 2013 08:11 AM
donzi16
May 23, 2011 06:38 AM
TacklaNHL
Dec 22, 2010 05:36 PM
