Volvo S40 2009 2.4L D5 R-Design SE - grease points?
Hello all,
First time on this forum since I bought a lovely 2009 Volvo S40 2.4L R-Design D5 and just completed an oil change. Would like to know all the grease points on this car?
Is there a diagram of all the points?
Thank you
Thank you
Dunno about the Gen 2s but on my Gen 1 the only lube points I know of are the hood hinges/catch latches, door hinges, door latches (there's a small rubber plug to give access on the rears), trunk hinges, catch latch and seat rails. You should inspect the rubber boots on the axles as they seal in the axle grease as part of your routine maintenance. I've also injected some Fluidfilm into the shifter release button as it can get sticky on the older models.
