Volvo s40 2012
Old Jan 11, 2016 | 04:28 PM
dale lloyd's Avatar
Default Volvo s40 2012
Only had the car 3 days and- REAR PARK ASSIST SERVICE -- has appeared ?
can take it back as i bought at auction
anyone know how to reset this fault ?
any help will be appreciated
Old Jan 14, 2016 | 04:58 PM
you may need some dealer help on this one. The DIY part would be to check the fuses and connections into the Park Assist module (make sure they are all seated properly and the module is properly secured in its spot). You may be able to inspect and clean the sensors too. After that the dealer would need to run diagnostics to see if one of the sensors is bad or the module itself. Not sure if the VIDA DICE units you can buy can do the diagnostics or not... a good question for anybody that owns a newer VIDA DICE set up.
Old Jan 16, 2016 | 07:57 AM
dale lloyd's Avatar
ok thanks plugged it into a diagnostics machine and no codes coming up for it
and in the last few days they have started to work again on there own but they
don't start beeping until your about 7 inches of the car behind you the ones on my renault witch I had previously they would work at bout 24" off anything around it
thanks Dale
brent@fluidequipment.com
Aug 17, 2014 12:32 PM
Slideordie
Dec 29, 2013 02:00 PM
v4vlv
Aug 6, 2012 01:18 AM
dantheman7
Jun 7, 2011 07:07 PM
