volvo s40 vibration and misfire
Old Dec 29, 2014 | 10:17 PM
pawright's Avatar
Default volvo s40 vibration and misfire
a couple of points about the car
1998 model s40
new coil packs and recently new genuine spark plugs as the non genuine ones that we installed when we did the coil packs failed.
2 litre non turbo motor
he these are two separate issues on idle the car has a lot of engine vibration by holding one foot on the brake and giving it slight acceleration it goes away it has been annoying since we bought the car but hasn't got any better or worse regardless of any other improvements we have made.
the second issue is that we had misfire issues and replaced the non genuine spark plugs with genuine ones and the problem was solved but it is now starting to misfire again and i expect it is probably leads the question is what type of leads do people use and how long do they last?
Old Dec 30, 2014 | 02:25 PM
Hudini's Avatar
My 2001 ran fine until about 100k miles before it started misfiring and needed new plugs/wires/coils. So, in my humble opinion, it should last another 100k miles before needed the same tune-up. Ummm, good luck. I ended up replacing the coils a 2nd time at about 158k miles.
Your description of the vibration sounds like motor mounts, specifically the bottom 2 mounts. (and luckily, the cheapest of the 4)
Old Dec 30, 2014 | 08:10 PM
TEEKAY's Avatar
Are you getting any codes? I've had misfires with map/mat sensor that needed replacement before.
Old Dec 31, 2014 | 03:14 AM
pawright's Avatar
what brand of leads do people use?
Old Dec 31, 2014 | 07:57 AM
Hudini's Avatar
I've used these:
Volvo Spark Plug Wire Set S40 V40 BOUGICORD 112454 1275603
Old Jan 1, 2015 | 11:18 AM
TEEKAY's Avatar
Switched to magnecor the other weekend. (Got them from THMotorsports at a recommendation from a dominator on 30forty50)
Amazon.com: Magnecor 45436 8.5mm KV85 CN Series Ignition Cable Volvo S40 2000-2004: Automotive Amazon.com: Magnecor 45436 8.5mm KV85 CN Series Ignition Cable Volvo S40 2000-2004: Automotive
ocean238
Apr 17, 2008 06:20 PM
khany1
Dec 30, 2007 10:34 AM
hwy9rnr
Feb 22, 2005 10:54 AM
