VVT exaust Cam
Old Feb 4, 2017 | 09:34 AM
s40200's Avatar
Default VVT exaust Cam
I was wondering if the exhaust cams aren't interchangeable between different size engines
for example
the 2001 s40 i have to one i found at salvage yard not sure which volvo model
I did take a picture of sticker under the hood though.
Mine has the small plunger
the one igot is sealed.
Engine group b5244t
Old Feb 4, 2017 | 12:53 PM
ES6T's Avatar
The 2001 S40 is a 4 cylinder and the B5244T is a 5 cylinder. The cam cannot be swapped. Neither can the VVT.
Old Feb 4, 2017 | 01:47 PM
s40200's Avatar
i think my leak is from seal on vvt oil cover.
Old Feb 4, 2017 | 02:41 PM
s40200's Avatar
nope oil cover is good
leaking from front of it where it bolts together
Old Feb 7, 2017 | 11:46 AM
s40200's Avatar
Ok so i bit the bullet an ordered a new exhaust vvt cam.
Can someone please tell me if this is correct
Once i lock cams with tool, remove gear ,install new gear .
align timing mark to timing mark on cover.
tourque bolt then im good?
Old Feb 8, 2017 | 05:46 AM
Hudini's Avatar
Yes, that is it. The cam holder makes it straight forward.
Old Feb 15, 2017 | 10:09 AM
s40200's Avatar
Just received my NEW genuine volvo vvt cam.
this weekend i plan to install it without completely removing the timing belt.
Has anyone here tried this?
Old Feb 15, 2017 | 10:19 AM
ES6T's Avatar
If the belt has oil on it, it should be replaced.
Old Feb 15, 2017 | 10:29 AM
s40200's Avatar
yea I was thinking that
But it only a minuscule amount the belt is brand new and so far car has only idled in driveway, but i might doit
Old Feb 15, 2017 | 10:45 AM
pierremcalpine's Avatar
I have not...having done the job the long way (locking cams and crank) and having done it twice I can tell you that this thing is very finicky as far as getting the exhaust gear correctly aligned. And if you don't get it right, you get a daily reminder that you f'd up with the stupid Check Engine Light. Seems like you'll be spending a bunch of time and effort anyway trying to keep tension on belt, tensioner, intake while you are fiddling with the exhaust gear. I'm not sure you will be ahead when it's all said and done. Let us know how you make out!
Old Feb 15, 2017 | 11:38 AM
ES6T's Avatar
Might consider doing cam seals at the same time. It would be easiest to remove the belt so you can get it all cleaned out in there.
Old Feb 15, 2017 | 12:07 PM
s40200's Avatar
Cam seals were done the first time I did the timing belt and found that the VVT gear was actually still leaking so seals are good.
Old Feb 15, 2017 | 12:24 PM
s40200's Avatar
any tips on getting the exhaust gear perfect don't want to deal with the check engine light
Old Feb 15, 2017 | 01:20 PM
Here's a guide I put together that may help you. As I recall the real tricks are a) leaving the vvt gear loose until the belt tension is correctly set and THEN tightening, and b) adjusting the tensioner while making sure that the belt is nice and tbetween the crank and intake valve. This will ensure that the tension throughout the assy is equal once the tensioner is adjusted. http://dmiller.sofi.org.uk/volvo/vvt..._servicing.pdf
Old Feb 15, 2017 | 03:08 PM
s40200's Avatar
thanks you guys are great when I finish I'll report back and let you know what I did and maybe it'll help somebody else out also
Old Feb 15, 2017 | 05:53 PM
s40200's Avatar
thank you for the guide
Old Feb 19, 2017 | 01:13 AM
  #17
s40200's Avatar
Well I ended up installing my vvt today.
All went good.
Trying to slide it on without removing everything was a no go.
Hopper
1998-2000 model year V70
Sep 15, 2012 10:48 PM
Riculus
May 14, 2008 07:53 AM
Pv12345
Oct 11, 2007 08:33 AM
HelgaTheS80
Mar 23, 2007 03:57 PM
colgate41
Apr 7, 2006 03:25 PM
