warning light for bulbs
Old Apr 17, 2012 | 10:38 AM
alanandrew12's Avatar
Default warning light for bulbs
Hi there the warning light for my bulbs is on and i have changed all bulbs from leds today and the light is still on any ideas anyone ..
Old Apr 17, 2012 | 11:18 AM
ShowTek's Avatar
Were they LED's before, or are they LED's now?
If LED's now, did you put the resistors/loads on?
Old Apr 19, 2012 | 07:29 AM
thanks thats sorted that problem out now i have another the person i brought it off has put vented disks and uprated pads and on the back has put bigger tyres on than the front would this affect the traction control and the stability of the car as the orange light is on the one with the triangle with the car skidding.thanks alan.
Old Apr 19, 2012 | 07:53 AM
curtmaxwall's Avatar
Post
Stability, I can say not much more at normal speed but yes there will be significant affect in traction from the wheel. Bigger the size of the wheel, more traction you will get. But same traction from both the wheel is also necessary.
Old Apr 19, 2012 | 08:21 AM
GerBeGurGya's Avatar
Having a FWD the bigger rears has no practical advantage in fact
it has all the bad effects.The bigger tires a probably not only wider bu taller as well.Having this circunference diference the traction thinks the front wheel is
spinning.I guess it tried to compesnsate by cutting fuel and when it didnt help it went offline.Traction Control gets its signal from the ABS sensors meaning your ABS is also could be confused and comprinised.Also now the car drags its rear as a wider tire produce more traction you will see a drop in the MPG.Match the fronts at least if you wanna go wit wider tires having them on the rear only makes no sense on a FWD.
Volvo_Neps
1998-2000 model year V70
Sep 12, 2024 06:53 AM
WalterXI
Nov 25, 2012 04:44 AM
TDolce
Oct 26, 2007 05:52 PM
Gordon
Jun 28, 2007 09:26 AM
panopticon
Mar 21, 2005 09:38 PM
