940 Bulb Warning Light on, all bulbs work !
Old Nov 22, 2012 | 09:01 AM
WalterXI's Avatar
Default 940 Bulb Warning Light on, all bulbs work !
What the hell is going on?
Like the title says the Bulb warning light is on, but they all work. Now I did have to replace a headlight plug yesterday, got it all wired in, everything works as it's supposed to, but the light won't go out.
argh. Any suggestions??
Old Nov 22, 2012 | 09:15 AM
lev's Avatar
lev
That system is TOO touchy! If bulbs have any variation at all, sometimes just being a different brand, you may get that warning light. It is unfortunately an annoying Volvo feature...
Old Nov 22, 2012 | 09:24 AM
act1292's Avatar
As lev pointed out, it is a sensitive system. It basically looks for a difference in current draw between the pairs of lights. When you replaced the headlight plug, did you replace the bulb as well? Sometimes it solves the problem by replacing bulbs in pairs - making sure you have the same brand in the pair.
Also, how did you connect in the new headlight plug? I always solder my wire splices and use heat shrink tubing to seal. Make sure the new plug has a good connection. It may work ok but could cause a different current draw than the other side.
Old Nov 24, 2012 | 08:11 AM
WalterXI's Avatar
Thanks for the feedback guys. I did replace both bulbs at the same time but I didn't have a solder gun lying around to work with so I just crimped them instead.
If/when I can get the chance to solder I will, if not I'm not going to worry then.
But you guys are right...the system is way to picky !!!
Old Nov 25, 2012 | 04:44 AM
the sensor can contains pairs of coils counter wound around magnetic reed relays. if any of the reeds is triggered, the bulb failure light comes on.
In each pair, one coil goes to each bulb, and the windings going opposite directions cancels the magnetic field if the current is exactly the same. old socket contacts or connectors in the wiring harness can have higher resistance, etc, and make them uneven even if the bulbs are matched.
alanandrew12
Apr 19, 2012 08:21 AM
WalterXI
Apr 6, 2010 10:55 PM
rkrepps
Mar 13, 2010 05:23 PM
TDolce
Oct 26, 2007 05:52 PM
master_pre
Oct 22, 2006 12:29 PM
