Water Leak From Center Console (passenger side)
Noticed that passenger side carpet was wet so removed it to dry and look for source of leak.
I have isolated the water source to the passenger side/center console area. The water only drips when the A/C is running.
Does anyone know how to correct this or what the cause could be? Any help would be greatly appreciated. Thanks!
I am still at a loss. It seems that the water is dripping from the lowest point on the heat exchanger. However, I am unable to determine the source.
Have you (or anyone) had any luck resolving this?
This seems to be a common sign of a clogged A/C drain tube. The drain is located on the passenger side of the exhaust tunnel. Ive had a couple of theses cars with the same problem.
Qamar
Nov 14, 2005 12:53 AM
