Weird start after air filter change
Old Aug 5, 2016 | 09:58 AM
Fer71457's Avatar
Default Weird start after air filter change
Hello, I'm new in the forum and I was wondering if anyone know why my s40 start like with missing power, to be more specific about the problem, I have a s40 II t5 2008, after changing the mass air filter the car start like it would start when is hot, like if he lost power.
Thank you for your time
Old Aug 7, 2016 | 10:49 PM
AutoNaut's Avatar
What brand filter did you use? Could it be too restrictive? Changing the filter should not cause an issue. Could you have done something else that may have knocked off a vacuum hose?
Stan
Old Aug 8, 2016 | 10:40 AM
Fer71457's Avatar
Stan
I cleaned the original one (I know I shouldn't do that but I have to prove it) and it seems that the problem was the filter, the engine is running "normal" now, the filter was a fram, thank you for your time
Old Aug 9, 2016 | 11:56 AM
Best to use OEM paper filters. Volvo intakes are pretty well designed so there's no noticeable benefit to a KN filter or cold air intake etc. Similarly after market oil filters can be more restrictive than OEM and can result in lower than acceptable oil pressure.
Old Aug 9, 2016 | 10:35 PM
AutoNaut's Avatar
I agree about the K&N filter. I saw no benefit in power or fuel economy. Based on oil analysis, they don't filter as well as a good paper filter. Bob the Oil Guy can always tell if you are running a K&N just by the particulate in the oil. That is not to say that the particulate is at harmful levels.
debargha
Feb 24, 2015 10:46 PM
swiftjustice44
Oct 25, 2012 06:32 AM
jus4
Oct 6, 2012 07:08 PM
