WHAT TO DO WITH CHECK ENGINE CODES AFTER AN ENGINE REPLACEMENT?
Old Mar 24, 2008 | 09:36 PM
Bruno937's Avatar
Default WHAT TO DO WITH CHECK ENGINE CODES AFTER AN ENGINE REPLACEMENT?
As some of you already I've replaced my 01 S40's engine with a 00 S40 engine and turbowith only 18K and the car is running great except:
The check engine light is on and local Parts Store found 12 codes of all kinds but I know none are correct because the engine is so new, one code is tranny relatedand..
Once in a while tranny upshift lightgoes on and the car picks up slow, I restart the car and everythings ok,
Again once in a while the brakes will get hard as if there is no power brakes,
My mechanic says drive around a couple of hundred miles, that should syncronize the computer and sensors then I may have to go to Volvo to reset the computer?
What do you think? What is the cheapest way of clearing this issue totally. I am trying to sell the car and can't drive the car around with no plates. But don't want to sell it with check engine light on either.
Old Mar 24, 2008 | 10:02 PM
Default RE: WHAT TO DO WITH CHECK ENGINE CODES AFTER AN ENGINE REPLACEMENT?
The parts store wouldn't clear them?
Old Mar 24, 2008 | 11:01 PM
Bruno937's Avatar
Hi, Tech. Long time no see.. The guy said he is not supposed to but I have another Parts store where the manager is a cool guy and will do it. Do you think once he clears them some won't come back on? Do I still have to drive the car for a couple of hundred miles? Thanks.
Old Mar 25, 2008 | 08:31 AM
Hudini's Avatar
Clear the codes and start fresh. If they come back then take a closer look.
vipul_vips
Jan 13, 2011 09:56 PM
wieder
Sep 10, 2010 08:42 PM
gabyman97596
May 14, 2007 09:52 PM
cranky
Aug 5, 2005 09:46 PM
